13 years agoROM contents confusion
Hai, I have vhdl code for store a constant in ROM. The ROM is divided into odd and even; ROMO and ROME as shown below:
library IEEE; use IEEE.STD_LOGIC_1164.all; -- use ieee.STD_LOGI...
13 years ago --- Quote Start --- I'm sorry you code is extremely difficult to read. Could you repost it with newlines? In any case, it seems to use the (bad) conv_std_logic_vector function a lot... --- Quote End --- Hai Daixiwen, Below is the code,hope you can help. Thanks in advance.
-- 5:0
-- 5:4 = select matrix row (1 out of 4)
-- 3:0 = select precomputed MAC ( 1 out of 16)
library IEEE;
-- use ieee.STD_LOGIC_signed.all;
use IEEE.STD_LOGIC_arith.all;
use WORK.MDCT_PKG.all;
entity ROMO is
port(
addr : in STD_LOGIC_VECTOR(ROMADDR_W-1 downto 0);
clk : in STD_LOGIC;
datao : out STD_LOGIC_VECTOR(ROMDATA_W-1 downto 0)
end ROMO;
architecture RTL of ROMO is
type ROM_TYPE is array (0 to 2**ROMADDR_W-1)
of STD_LOGIC_VECTOR(ROMDATA_W-1 downto 0);
constant rom : ROM_TYPE :=
(others => '0'),
conv_std_logic_vector( GP,ROMDATA_W ),
conv_std_logic_vector( FP,ROMDATA_W ),
conv_std_logic_vector( FP+GP,ROMDATA_W ),
conv_std_logic_vector( EP,ROMDATA_W ),
conv_std_logic_vector( EP+GP,ROMDATA_W ),
conv_std_logic_vector( EP+FP,ROMDATA_W ),
conv_std_logic_vector( EP+FP+GP,ROMDATA_W ),
conv_std_logic_vector( DP,ROMDATA_W ),
conv_std_logic_vector( DP+GP,ROMDATA_W ),
conv_std_logic_vector( DP+FP,ROMDATA_W ),
conv_std_logic_vector( DP+FP+GP,ROMDATA_W ),
conv_std_logic_vector( DP+EP,ROMDATA_W ),
conv_std_logic_vector( DP+EP+GP,ROMDATA_W ),
conv_std_logic_vector( DP+EP+FP,ROMDATA_W ),
conv_std_logic_vector( DP+EP+FP+GP,ROMDATA_W ),
(others => '0'),
conv_std_logic_vector( FM,ROMDATA_W ),
conv_std_logic_vector( DM,ROMDATA_W ),
conv_std_logic_vector( DM+FM,ROMDATA_W ),
conv_std_logic_vector( GM,ROMDATA_W ),
conv_std_logic_vector( GM+FM,ROMDATA_W ),
conv_std_logic_vector( GM+DM,ROMDATA_W ),
conv_std_logic_vector( GM+DM+FM,ROMDATA_W ),
conv_std_logic_vector( EP+FM,ROMDATA_W ),
conv_std_logic_vector( EP+DM,ROMDATA_W ),
conv_std_logic_vector( EP+DM+FM,ROMDATA_W ),
conv_std_logic_vector( EP+GM,ROMDATA_W ),
conv_std_logic_vector( EP+GM+FM,ROMDATA_W ),
conv_std_logic_vector( EP+GM+DM,ROMDATA_W ),
conv_std_logic_vector( EP+GM+DM+FM,ROMDATA_W ),
(others => '0'),
conv_std_logic_vector( DM+EP,ROMDATA_W ),
conv_std_logic_vector( DM+GP,ROMDATA_W ),
conv_std_logic_vector( DM+GP+EP,ROMDATA_W ),
conv_std_logic_vector( FP+EP,ROMDATA_W ),
conv_std_logic_vector( FP+GP+EP,ROMDATA_W ),
conv_std_logic_vector( FP+DM,ROMDATA_W ),
conv_std_logic_vector( FP+DM+EP,ROMDATA_W ),
conv_std_logic_vector( FP+DM+GP,ROMDATA_W ),
conv_std_logic_vector( FP+DM+GP+EP,ROMDATA_W ),
(others => '0'),
conv_std_logic_vector( FM+DM,ROMDATA_W ),
conv_std_logic_vector( FM+EP,ROMDATA_W ),
conv_std_logic_vector( FM+EP+DM,ROMDATA_W ),
conv_std_logic_vector( GP+DM,ROMDATA_W ),
conv_std_logic_vector( GP+EP,ROMDATA_W ),
conv_std_logic_vector( GP+EP+DM,ROMDATA_W ),
conv_std_logic_vector( GP+FM,ROMDATA_W ),
conv_std_logic_vector( GP+FM+DM,ROMDATA_W ),
conv_std_logic_vector( GP+FM+EP,ROMDATA_W ),
conv_std_logic_vector( GP+FM+EP+DM,ROMDATA_W )
begin
process(clk)
begin
if clk = '1' and clk'event then
datao <= rom( CONV_INTEGER(UNSIGNED(addr)) );
end if;
end process;
end RTL; -- 5:0
library IEEE;
entity ROME is
port(
clk : in STD_LOGIC;
end ROME;
architecture RTL of ROME is
type ROM_TYPE is array (0 to (2**ROMADDR_W)-1)
(others => '0'),
conv_std_logic_vector( AP,ROMDATA_W ),
conv_std_logic_vector( AP+AP,ROMDATA_W ),
conv_std_logic_vector( AP+AP+AP,ROMDATA_W ),
conv_std_logic_vector( AP+AP+AP+AP,ROMDATA_W ),
(others => '0'),
conv_std_logic_vector( BM,ROMDATA_W ),
conv_std_logic_vector( CM,ROMDATA_W ),
conv_std_logic_vector( CM+BM,ROMDATA_W ),
conv_std_logic_vector( CP,ROMDATA_W ),
conv_std_logic_vector( CP+BM,ROMDATA_W ),
(others => '0'),
conv_std_logic_vector( BP,ROMDATA_W ),
(others => '0'),
conv_std_logic_vector( BP+CM,ROMDATA_W ),
conv_std_logic_vector( BP+CP,ROMDATA_W ),
(others => '0'),
(others => '0'),
conv_std_logic_vector( AM,ROMDATA_W ),
(others => '0'),
(others => '0'),
conv_std_logic_vector( AM+AM,ROMDATA_W ),
(others => '0'),
(others => '0'),
(others => '0'),
(others => '0'),
conv_std_logic_vector( BM+CM,ROMDATA_W ),
(others => '0'),
(others => '0'),
conv_std_logic_vector( CP+BP,ROMDATA_W ),
(others => '0')
begin
process(clk)
begin
datao <= rom(CONV_INTEGER(UNSIGNED(addr)) );
end if;
end process;
end RTL;
