GWang31
7 years agoRisk of one pin of 3.0 VCCIO bank connect to 5V logic?
Hello, I wrongly connect an I/O pin which is in 3.0V bank to 5V logic. I wonder will the damage(if happens) only affect to this specific pin or the whole FPGA? Will it help if I set this pin to hig...
AnandRaj_S_Intel
7 years agoHi,
Check your device Data Sheet for Absolute Maximum Ratings.
- If we Operate a device in Absolute Maximum Ratings may cause permanent damage to the device.
- The device output pins do not meet the I/O standard specifications if the VCCIO level is out of the recommended operating range for the I/O standard.
- If high-z may impact on power-on-reset.
Anand
GWang31
7 years agoThanks Anand. The maxinum ratings on datasheet of cyclone IV is 4.2V, now the IO pin I connect to 5V logic output by mistake. I know there may be damage to the device. I wonder what the "damage to the device" means. Does it mean the damage to the pin or the whole FPGA? Will the FPGA die?
