Risk of one pin of 3.0 VCCIO bank connect to 5V logic?
I wrongly connect an I/O pin which is in 3.0V bank to 5V logic. I wonder will the damage(if happens) only affect to this specific pin or the whole FPGA? Will it help if I set this pin to high-z state? The function of this pin is not in need in my design at present, I wonder if there is risk for my rest of FPGA pins. Thanks.
- Daixiwen
Is there a resistor limiting the current on that pin? Internally the FPGA has a clamping diode (if you didn't disable it) between the I/O pin and the VCCIO rail of that bank. If the diode is damaged due to the current, then the overvoltage could be transmitted to the VCCIO rail and this would damage more than just the I/O pin on the FPGA.
- AnandRaj_S_Intel
Yes, If a power supply pin is damaged due to over supply than it may establish a short between VCCIO and GND which means FPGA is damaged. So FPGA will not work.
Anand
- GWang31
Hi Anand,
This wrong connected pin is not power supply pin, will that make the FPGA don't work?
- AnandRaj_S_Intel
We can check the data sheet for DC input voltage.
5 volt is above Absolute Maximum Ratings. It will damage IO pin which may establish a VCCIO and GND short leads to FPGA damage.
Anand
- AnandRaj_S_Intel
Check your device Data Sheet for Absolute Maximum Ratings.
- If we Operate a device in Absolute Maximum Ratings may cause permanent damage to the device.
- The device output pins do not meet the I/O standard specifications if the VCCIO level is out of the recommended operating range for the I/O standard.
- If high-z may impact on power-on-reset.
Anand
- GWang31
Thanks Anand. The maxinum ratings on datasheet of cyclone IV is 4.2V, now the IO pin I connect to 5V logic output by mistake. I know there may be damage to the device. I wonder what the "damage to the device" means. Does it mean the damage to the pin or the whole FPGA? Will the FPGA die?
