dabo
3 years agoReuse programming file for multiple MAX 10 devices
We are looking for clarification when it is necessary to rebuild the project in Quartus when using different MAX 10 devices. As with many others we are having problems acquiring the MAX 10 d...
FakhrulA_altera
3 years agoHi dabo,
Please take note the I7 OPN devices are only validated and tested up to 100°C , thus using an I7 device will not improve the temperature support, it will still run hot. Also, the customer has to take their own risk of the functionality, performance, and reliability of the devices if they planned to run up to 125C while using I7. I got a case whereby a customer said the device runs hot when they're using I7 OPN up to 125°C.
Additionally, you may check the following KDB which applicable to your concerns:
Are programming and configuration files compatible across speed grades?
Fakhrul
