16 years agorestricted fmax
My design with a Stratix2GX130 is timing-clean (no findings in TimeQuest' "report top failing paths"). The design is fully constrained, everything seems to be ok. But when I look at the list o...
16 years agoThose values are valid and should not be ignored. If you attempt to exceed the restricted Fmax then you will be operating the device outside of spec and you should not expect it to function properly.
