15 years agoresize drawing
I am writing in hopes that you can help me resolve an issue. I have not been able to find an answer on any help or forum page. The problem is that once I complete a schematic sheet, if the cir...
15 years agoHi, it seems that you had some assignments or parameters at the IO pins which were incorrectly removed, so there were some residues in the BDF file. There were objects (annotation_block) which did not display in the editor, so you were not able to select them nor delete them, but they were occupying some place. So the editor did fit the schematic correctly to the display, there were just some symbols that you were not able to see.
I've deleted them manually from the BDF file.
