MK_ABQ
Contributor
3 years agoReset Vector - NIOS
I have a reference NIOS project in which the reset vector memory is selected as an external flash. I opened platform designer and found the following information. Picture attached below.
- 3 years ago
Hi MK,
Greetings and welcome to Intel's forum.
There is not specific reason why it is greyed out. It is according to the base address you set in Platform Designer. You have the flash address set to 0x10000000, and the offset to 0x08b00000. Therefore, flash will start access at 0x18b00000.
Hope this clarifies your doubts.
Thank you.
Kelly
KellyJialin_Goh
3 years agoHi MK,
May I know what are the additional comments or clarification needed? Without looking at your code, I am not able to further give comments or support.
Close pending means I will not be able to support your queries after and the community will be there to help you with your further queries.
Thank you.
Kelly
