10 years agoReset for PLL
I am working on a project involving Arria V FPGA.
I need to have a PLL for generating clocks for my internal FPGA logic. I am confused about the reset signal of PLL. I have no external H/W reset pin. To which pin must I connect this reset signal. I am deriving the reset signal for logics from PLL locked signal. I am thinking of connecting this pin to POR signal. How to access the power on reset pin? Are there any other suggestions for connecting PLL reset pin? Thanks12 Replies
There must be some official response from Intel about this somewhere. I can only imagine it's a very common question. Here are two solutions I have been using and found to work:
- Connecting the reset port to an external pin tied to ground on the PCB - Using the PLL reference clock to generate a registered reset signal (e.g., using a counter or shift register) The second solution could be expanded to reassert reset when lock is lost, however I thought this was precisely what the auto-reset setting was for, and hence I see no reason why Quartus does not allow you to tie reset to zero internally as in older families. - PNaja
I also have the same issue when I upgraded from Quartus 17.1 to 18.01 and later on to 18.1.
- The initial converted Arria 10 load compiled successfully
- Then I changed NIOS clock from my device_clk (connected to external pin) to a clock bridge connected to 100 MHZ external clock trying to reduce the clock to the NIOS max clock rate of 50 Mhz. This change was done in the platform designer.
- The RST_N error message is pointing to the two PLL's that were instantiated in the top level design and is not showing up in the platform designer.
- The change had nothing to do with the PLL, Why are we getting compile error on the part of the design that was not changed.
