10 years agoReset for PLL
I am working on a project involving Arria V FPGA. I need to have a PLL for generating clocks for my internal FPGA logic. I am confused about the reset signal of PLL. I have no external H/W reset...
PNaja
8 years agoI also have the same issue when I upgraded from Quartus 17.1 to 18.01 and later on to 18.1.
- The initial converted Arria 10 load compiled successfully
- Then I changed NIOS clock from my device_clk (connected to external pin) to a clock bridge connected to 100 MHZ external clock trying to reduce the clock to the NIOS max clock rate of 50 Mhz. This change was done in the platform designer.
- The RST_N error message is pointing to the two PLL's that were instantiated in the top level design and is not showing up in the platform designer.
- The change had nothing to do with the PLL, Why are we getting compile error on the part of the design that was not changed.
