Request for FA on EP4CGX22CF19C8N
Hi Wani,
Thanks for reaching out.
You may refer below.
1. What is the failure symptom? Please elaborate the failure symptom in detail.
ans: This unit failed blank display at customer side and returned as OBE. The failure was due to defective carrier board 5067-5849. The PCA was returned to VJB for failure analysis. Per update from VJB, PCA failed at ICT as short at U57. VJB claimed the short is due to defective U57.
2. When did the failure happen? How did you discover the failure?
3. How did you determine the failure? Please elaborate the procedures.
ans: We test the board under ICT (in-circuit test) and found this component was short to ground on the PCA. After checking under 5DX (X-ray test), there are no solder short found underneath the component. Hence we have suspected that component may be defect due to this reject.
4. Does the failure unit ever working before failure?
ans: Yes.
OBE: out of box experience. Means the reject was found at our end customer.
PCA/PCBA: Printed Circuit Board Assembly
Hi Intel Team,
May I get the update on this?
Can we send the component to you for validation?
