Request for FA on EP4CGX22CF19C8N
Hello Amirul Akmal,
Thank you for using Intel FPGA Community Forum.
Can you tell me a story of your failing part. Or you want to share something from my questions as follow.
1. What is the failure symptom? Please elaborate the failure symptom in detail.
2. When did the failure happen? How did you discover the failure?
3. How did you determine the failure? Please elaborate the procedures.
4. Does the failure unit ever working before failure?
Can you explain what is OBE and PCA?
Thank you!
Wani
- Amirul_Akmal3 years ago
Hi Wani,
Thanks for reaching out.
You may refer below.
ans: This unit failed blank display at customer side and returned as OBE. The failure was due to defective carrier board 5067-5849. The PCA was returned to VJB for failure analysis. Per update from VJB, PCA failed at ICT as short at U57. VJB claimed the short is due to defective U57.
ans: We test the board under ICT (in-circuit test) and found this component was short to ground on the PCA. After checking under 5DX (X-ray test), there are no solder short found underneath the component. Hence we have suspected that component may be defect due to this reject.
ans: Yes.
OBE: out of box experience. Means the reject was found at our end customer.
PCA/PCBA: Printed Circuit Board Assembly
Hi Intel Team,
May I get the update on this?
Can we send the component to you for validation?
