Reprogram max3000A when JTAG was disable.
Hello Every body,I get trouble with my design. I programmed Max3000A(epm3256), but i disabled JTAG. Now, i want to reprogram,how can i do?could you show me how to enable JTAG or reprogram EMP3256 without JTAG?i read in this thread http://www.alteraforum.com/forum/showthread.php?t=25392&highlight=reprogram+max3000a+when+jtag+was+disable.
But it still can not solve my problem. Thanks in advance!5 Replies
Yes, I guess in-system-programming isn't possible without special prerequisites in board design, as far as I know, at least for one special pin, the voltage must be raised to a level above VCC.
Thanks so much!Actually, my Chip already soldered on application board,i dont want remove it for reprogramming, that`s why im trying to find way that can reprogram via JTAG(even JTAG was disable) or other easy way.but now i know that is impossible.any way, thank you so much.hope that can recieve your supports in near future.
Ask Altera, which programmers are supporting non-JTAG programming of MAX 3000. Altera programming unit (APU) e.g. did, but it isn't manufactured any more. I expect, that some industry standard programmers will also support it.
thanks for your quick reply.I think so.I really want to reprogram my Chip.Do you know other way can program Chip without JTAG?for example using ISP.But i dont know clearly,i spend a lot of time for finding it.Thanks for your support.
I think the term one way ticket describes the JTAG-disable option correctly. Without a suitable high voltage programmer, you can't undo it. But personally I don't have additional informations about the details, simply because I don't need it.
