vankammen
4 years agoReplacement for Intel / Altera EPM570F256C5N
Experiencing a part allocation issue for the Intel / Altera EPM570F256C5N CPLD. Any suggestions for a drop-in replacement?
Ash_R_Altera
4 years agoHi, If you are moving from slower to faster speed grade device, then there will be no risk from timing perspective.
For faster to slower device, you should re-run the Timing Analysis only for the new device to check if you have sufficient margins and all constraints are met or not.
A way to do that is to create a Timing Netlists for different speed grades in Timing Analyzer tool and check the performance.
