16 years agoRemoving routing !!!!
I use Quartus 9.0 and I would like to remove only the inside routing without pins removing ! It’s possible? Thank you, Jean4 Replies
Can you tell us specifically which assignments you're seeing in the project that you want to remove?
Jake - Altera_Forum
I'm not sure, what you exactly mean with routing assignment, because it's no Quartus category in my opinion. To remove all compilation results, you can simply delete the db directory. Other specific assignments (beside pin location assignments) are accessible in the Assignment Editor tool and can be e.g. deleted there, if required.
In menu remove Assignments, I would like to remove only the Routing Assignment !!!!
And achieve what?
