16 years agoRemoving routing !!!!
Hi, I use Quartus 9.0 and I would like to remove only the inside routing without pins removing ! It’s possible? Thank you, Jean
16 years agoI'm not sure, what you exactly mean with routing assignment, because it's no Quartus category in my opinion. To remove all compilation results, you can simply delete the db directory. Other specific assignments (beside pin location assignments) are accessible in the Assignment Editor tool and can be e.g. deleted there, if required.
