Remote update, unable to create factory configuration
By "Configuration mode" (param 101) I have meant the value read from the IP with param set to b101.
Yes, I have meant the Application mode.
I am currently creating the .pof file using the "Convert Programming File" utility present in Quartus Prime such that I have 3 sof pages each with its own file.
After switching on, the FPGA is automatically loaded with the image from the page with the highest number.
This is how the pof is created
I would expect the default image to be considered the factory image and the others the application images but I may indeed be wrong and this is the part I do not understand fully.
Let me reformulate then. How does one mark an configuration as a factory configuration?
Also I am not using the Avalon interface.
Best regards
VN
