NRugg
5 years agoRemote Update IP - How to Debug Reconfiguration Issues
System:
Cyclone IV
NIOS II Soft Core Processor
EPCQ128 A used for holding fabric images
Programming file = .rpd (each byte bit swapped before writing to flash per documentation)
So in ...
- 5 years ago
Things to note about the final .rpd that worked
- Little Endian
- Bit Reversal handled in embedded code
- Generated pointing to EPCQ128 in the 'Convert Programming File' tool
- Active Serial (not x4, just normal)
NRugg
5 years agoAny thoughts on this?
I've tried every file type I know how, still with no luck.
- I made sure to generate the .rpd file using a version of Quartus that supports EPCQ128A
- I've tried both big and small endian versions of the above .rpd file
- I made sure to bit swap every byte before writing it to flash memory
- I can write and read back the memory contents of EPCQ128A accurately (aka confirmed data is getting written properly)
