12 years agoRemote update Flash EPROM (EPCS16) using lan/ uart
Hello all, i have question. I need to update throw ethernet my flash memory EPCS16 on some board with EP3C16 FPGA. The ethernet i convert to uart using xport and the data from uart i need to sa...
11 years agoFor an Nios based RSU example, you can also refer to Altera Wiki http://www.alterawiki.com/wiki/epcs_based_remote_system_update_(rsu)_example_on_bemicro_sdk
I don't use remote system upgrade with NIOS, but at first sight you are setting the boot address right. Other parameters must be set, too. The watchdog must be e.g. explicitely disabled.
