12 years agoRemote update Flash EPROM (EPCS16) using lan/ uart
Hello all, i have question. I need to update throw ethernet my flash memory EPCS16 on some board with EP3C16 FPGA. The ethernet i convert to uart using xport and the data from uart i need to sa...
11 years agoNo idea why the configuration request isn't working.
You should check in the technology mapper view how the reconfic signal is actually connected. You also must select Configuration Mode = Remote under Assignments/Device/Device and Pin Options/Configuration/ (set_global_assignment -name STRATIXIII_UPDATE_MODE REMOTE).
