12 years agoRemote update Flash EPROM (EPCS16) using lan/ uart
Hello all, i have question. I need to update throw ethernet my flash memory EPCS16 on some board with EP3C16 FPGA. The ethernet i convert to uart using xport and the data from uart i need to sa...
11 years agoIt is not so simple how you write or i have some error on my design or program. I have design, where i have altremote_update0 megafunction connect to NIOS2/f to LED_BASE led[15] to reconfig pin and led[14] to reset pin and i have this part of program:
----------------------------------- printf("Restart altremote_update.\n"); IOWR_ALTERA_AVALON_PIO_DATA(LED_BASE,0x4000); usleep(10000); IOWR_ALTERA_AVALON_PIO_DATA(LED_BASE,0x0); // open flash printf("Oteviram flash EPROM.\n"); fd = alt_flash_open_dev("/dev/epcs_flash_controller_0"); if (fd!=NULL) { printf("Info flash EPROM.\n"); ret_code = alt_get_flash_info(fd, ®ions, &number_of_regions); if (!ret_code) { printf("Flash EPROM obsahuje %d sektoru.\n", regions->number_of_blocks); for(n=0;n<regions->number_of_blocks;n++) { printf("Erase %d.sector.\n",n); if (fd!=NULL) alt_erase_flash_block(fd, n*65536, 65536); } printf("Wait on data in UART.\n"); } } init_uarts(); // main cycle while (1) { // write uarts data to flash eprom if (rx_lan_flag1==1) { alt_printf("%x ",blok_cnt); // reverzuj bity ReverseBitsInBytes(data_written, 256); // write block if (fd!=NULL) ret_code = alt_write_flash_block(fd, 0, blok_cnt*256, data_written, 256); rx_lan1=0; rx_lan_flag1=0; blok_cnt++; } // read data if (blok_cnt==16*256) { printf("Reading flash EPROM.\n"); for(m=0;m<blok_cnt;m++) { ret_code = alt_read_flash(fd, m*256, data_read, 256); // reverzuj bity ReverseBitsInBytes(data_read, 256); // list only 16 bytes from 256-bytes block printf("%04X:",m); for(n=0;n<16;n++) { printf("%02X",data_read[n]); } printf("\n"); } printf("Close flash EPROM.\n"); alt_flash_close_dev(fd); blok_cnt=0; printf("Perform reconfiguration - write 1 to config.pin.\n"); IOWR_ALTERA_AVALON_PIO_DATA(LED_BASE,0x8000); usleep(10000); IOWR_ALTERA_AVALON_PIO_DATA(LED_BASE,0x0); } ------------------------------ Everything is ok, but reconfiguration does not start after IOWR_ALTERA_AVALON_PIO_DATA(LED_BASE,0x8000); usleep(10000); IOWR_ALTERA_AVALON_PIO_DATA(LED_BASE,0x0); When i turn off and turn on power supply of the board, it takes the bitstream which i programed to flash and it work well. Is possible to set some registers on altremote megafunction or something else ? Clock for NIOS is 120MHz and for altremote megafunction 20MHz. In NIOS is not any timer ... Thank you for your answer. Jan
