12 years agoRemote update Cyclone IV from EPCS
Hello. I have DE2-115 and i'm able to reconfig it from EPCS with NIOS. But I have some problems with factory image. My factory image takes addresses in EPCS from 0x0 to 0xF0000. (Sectors...
12 years agoPlease check these points:
- Are you sure you are correctly erasing sector 16? Try to read back epcs data. Maybe you are actually erasing sector 0. - Does the FPGA+NIOS image really fits between 0 and 0xF0000? I would expect a bigger image for the C-IV device used on the DE2-115. - After power up, check if FPGA doesn't reconfigure at all or if instead it configures but Nios doesn't boot.
