16 years agoRemote Update Cyclone III from EPCS
I am able to load in an Application configuration from a specified address in the EPCS, but after a certain time the device reconfigures itself with the Factory configuration (at address 0). I ...
15 years agoThanks very much for your quick reply.
Following on the same,the image update circuit has the controller logic & update logic. The controller logic reads the data from I2C and the update logic writes the image from the controller logic to EPCS. Its not fully clear to me how to use I2C with controller logic. The I2C that i'm using has both slave and master pins. Greatly appreciate your inputs.
