16 years agoRemote Update Cyclone III from EPCS
I am able to load in an Application configuration from a specified address in the EPCS, but after a certain time the device reconfigures itself with the Factory configuration (at address 0). I ...
15 years agoBrunda - Yes, you need the ALTASMI core in your code. The pin mapping is transparent but you need it there to make the connection between your state machine and the ASMI (hard macro) block itself.
