14 years agoRemote update controller issue
Hi everyone,
I'm using the remote update controller (cyclone III) on my Cyclone IV GX dev board with a EPCS128 flash memory. I wish to have two firmwares in my EPCS (factory and application). Actually, I placed the firmware like this in the EPCS: 0x000000 Factory image (hw0 + sw0) 0x440000 Application image (hw1 + sw1) (I'm not using the flash programmer to load the image in flash memory) The nios II boots correctly on the factory image when I start the board. But when I try to reconfig the FPGA with the application image using the remote update controller, the Factory image is loaded... I write 0x110000 to the remote update controller, then start the reconfig for loading the application image. Is this address correct? I think my problem comes when I'm creating the application image. Here is my script to create the .flash: --- Quote Start --- java -jar C:\altera\11.0\nios2eds\bin\sof2flash.jar --epcs --input="..\..\2Dcam.sof" --output="2Dcam_sof.flash" --verbose java -jar C:\altera\11.0\nios2eds\bin\elf2flash.jar --epcs --after="2Dcam_sof.flash" --input="..\2DCam\2DCam.elf" --output="2DCam_elf.flash" --offset 0 rem merge the two files copy /b /y 2Dcam_sof.flash+2DCam_elf.flash 2DCam.flash --- Quote End --- I create factory and application image (.flash) with this script. And load the factory image at address 0x000000 and the application at address 0x440000 in EPCS. Do I have to make something different for the application image, because her address is not 0x000000? Has anyone the same problem? Best regards
