14 years agoRemote update controller issue
Hi everyone, I'm using the remote update controller (cyclone III) on my Cyclone IV GX dev board with a EPCS128 flash memory. I wish to have two firmwares in my EPCS (factory and application)....
14 years agoHi,
Attached is my solution. In the .zip, you have all the files needed for the .bat. 1) Enter your application address (IMAGE_START) in boot_loader_epcs_bits_sii_siii_ciii.S file 2) running this .bat 3) copy SOPC_2Dcam_epcs_flash_controller_0_boot_rom_synth.hex in your <project>/SOPC_folder/synthesis/submodules/ 4) In Quartus, Processing -> Update Memory Initialization File 5) In Quartus, Processing -> Start -> Start Assembler Be careful, the .bat is for Quartus v11.1, if you are using another version. Open the .bat file with a text editor and change all 11.1 with your version number. for example: --- Quote Start --- set PATH=%PATH%;C:\altera\11.1\quartus\bin; -> set PATH=%PATH%;C:\altera\12.0\quartus\bin; --- Quote End ---
