14 years agoRemote update controller issue
Hi everyone, I'm using the remote update controller (cyclone III) on my Cyclone IV GX dev board with a EPCS128 flash memory. I wish to have two firmwares in my EPCS (factory and application)....
14 years agoThank you hallodu, your solution for creating the bootloader for a User Image works fine for me in a Cyclone IV device with Quartus 12.0.
Cheers :o --- Quote Start --- Hi, Attached is my solution. In the .zip, you have all the files needed for the .bat. 1) Enter your application address (IMAGE_START) in boot_loader_epcs_bits_sii_siii_ciii.S file 2) running this .bat 3) copy SOPC_2Dcam_epcs_flash_controller_0_boot_rom_synth.hex in your <project>/SOPC_folder/synthesis/submodules/ 4) In Quartus, Processing -> Update Memory Initialization File 5) In Quartus, Processing -> Start -> Start Assembler Be careful, the .bat is for Quartus v11.1, if you are using another version. Open the .bat file with a text editor and change all 11.1 with your version number. for example: --- Quote End ---
