14 years agoRemote update controller issue
Hi everyone, I'm using the remote update controller (cyclone III) on my Cyclone IV GX dev board with a EPCS128 flash memory. I wish to have two firmwares in my EPCS (factory and application)....
14 years agoI figure out the difference. When executing "make" command, I should do it like this:
make CODE_BASE=0 Then the generated code in boot_loader_epcs_sii_siii_ciii.elf will start at address 0x0. Now by virtue of this commandelf2hex --input=obj/boot_loader_epcs_sii_siii_ciii.elf --output=kernel_epcs_boot_rom_synth.hex --width=32 --base=0 --end=0x3ff --record=4 --lower the required boot loader code file(i.e. the .hex file) will be generated. -wei
