12 years agoRemote Configuration scheme
Hi Guys, I am using the following configuration scheme, want your suggestions and opinions on the same. (configuration image attached) 1. The Master FPGA boots itself from Serial Configuration...
12 years agoBasically, I want to reconfigure the slave FPGAs through Ethernet, USB and UART which are interfaced with the Master Controller.
Also, slave FPGAs being interfaced with the master in 19 inch backplane, using serial transceiver seems an ideal choice (as their would be latching problem in parallel data bus)
