17 years agoRegarding custom logic issue in sopc
I am running software example given with nios II that prints "Hello world". It uses nios CPU, onchip memory, led pio, jtag. I have generated my own custom logic and connect to these component using...
17 years agoYou can't really force the NIOS to do bursts. You can configure it to do bursts and you may be able to take advantage of the data cache to get it to do bursts.
If you need some high performance data transfer then you should use a DMA controller; either your own custom logic or one of the Altera DMA controllers. Jake
