16 years agoreg critical warning
hi 1.in my design using cyclone3 critical warning "RULE D101 is violated "is coming 2. but my design is working properly, there is any problem if i proceed with critical warning regards
16 years agoHello mkraj33, your design may work temporarily, but a long run it may fail. You can do a long run check and verify still the logic works. If you are using dual clocks it is always a good practice to synchronize between clock domains otherwise you will end up with unpredictable results.
