16 years agoReduce Clock Setup and Clock Hold times
Hi there, I have a state machine witch makes some math operations. The question is how can I reduce the clock setup and hold times, so I can meet my timing requirements? Here is the code of the st...
16 years agoOK, I have one question now :). Does this mean that if I make a PLL clock multiplier, for example 80MHz and if timings are OK at 20MHz they would be OK at 80MHz as well. What I mean is that the synthesis is adjusted to the clock speed and the connection timings will be proportional to 20MHz?
Best regards, VT
