9 years agoReduce clock frequency when system clock is dynamic
Hi, I would like to know a method to divide the clock to a certain frequency. I am aware of different methods of clock divider but the thing here is that the on-board system clock is dynamic (not fix...
9 years ago --- Quote Start --- --- Quote Start --- 'Guess/calculate the accurate frequency of the internal clock?' ... You can assume, as I said before, the internal clock will be between 3.9 and 5.3MHz. Or as 4.6MHz +/- 0.7MHz. So I suppose you could 'guess' 4.6MHz, but it has a +/- 700KHz uncertainty. I see. Thanks for the clarification. Last question: Is it only necessary to create SDC files if I want to analyze the timing or do I need to create it each time in order to generate the bin file? --- Quote End --- The .sdc files are not just for timing analysis. They also provide info to the fitter in driving the place and route. So the more guidance you can provide to the tool, the better design you will get.
