9 years agoReduce clock frequency when system clock is dynamic
Hi, I would like to know a method to divide the clock to a certain frequency. I am aware of different methods of clock divider but the thing here is that the on-board system clock is dynamic (not fix...
9 years ago --- Quote Start --- 'Guess/calculate the accurate frequency of the internal clock?' ... You can assume, as I said before, the internal clock will be between 3.9 and 5.3MHz. Or as 4.6MHz +/- 0.7MHz. So I suppose you could 'guess' 4.6MHz, but it has a +/- 700KHz uncertainty. I see. Thanks for the clarification. Last question: Is it only necessary to create SDC files if I want to analyze the timing or do I need to create it each time in order to generate the bin file?
