11 years agoReconfigure FPGA another using NIOS II SoC
HI, I'm working on a research project on hardware software partitioning. I'm trying to edit the hardware task list dynamically and I'm in a trouble doing reconfigure another FPGA using NIOS II proces...
11 years ago --- Quote Start --- Cyclone IV devices are not supported for this --- Quote End --- The Cyclone IV devices support passive serial mode and configuration from SPI flash. Take a look at the TS4 design documentation on this page: https://www.ovro.caltech.edu/~dwh/wbsddc/ (The board never made it to the 'real-world', but the design files have useful info) If you need fast configuration, then you can use a MAX II or MAX V device as the programmer (passive serial controller), and Quad-SPI flash as the data source. The MAX II/V can read the flash at up to 100MHz, so you can program the Cyclone IV fairly quickly. Cheers, Dave
