13 years ago
Reading a Text File
Hi to all,
I am trying to read a text file has some values in character type as follow:
21
30
36
30
17
14
13
13
but what I am getting wrong values as follow:
50
49
10
51
48
10
51
based in the following code:
library ieee;
USE ieee.std_logic_1164.all;
USE ieee.numeric_bit.ALL;
USE std.textio.all;
Entity feeder Is
port ( start: in std_logic;
pixel_value: out bit_vector(7 downto 0)
END feeder;
Architecture Behavior OF feeder Is
TYPE frame_txt IS FILE OF character;
TYPE frame_array IS ARRAY (natural RANGE <>) OF bit_vector(7 DOWNTO 0);
SIGNAL read_frame_array : frame_array(0 to 25343);
begin
read_file: PROCESS (start) IS
FILE file_in : frame_txt OPEN read_mode IS " /afs/cad/u/s/m/smb34/vlsi2/frame1.txt"; -- open the frame file for reading
VARIABLE char_buffer : character;
BEGIN
IF start'EVENT AND start = '1' THEN
FOR i IN read_frame_array'RANGE LOOP
read(file_in, char_buffer);
read_frame_array(i) <= bit_vector(to_unsigned(character'POS(char_buffer), 8));
pixel_value <= read_frame_array(i);
--frame_array_byte(i) <= CONV_STD_LOGIC_VECTOR(character'pos(char_buffer), 8);
END LOOP; -- i
file_close(file_in);
END IF;
END PROCESS read_file;
End Behavior;
please, let me know what i have done wrong, so i can read the write values out of the file?!
    thanks so much , not only for solving my problem but also for explaining to me why it went wrong.
    This undefined 'U' states occur when signals do not have a defined state right from the beginning of the simulation.
    We can get rid of this by changing the process to this code:
        read_file : PROCESS IS
            FILE file_in     : text;          -- file ID
            VARIABLE line_rd : line;          -- text line
            VARIABLE data_in : integer;       -- integer data input
            VARIABLE i       : integer := 0;  -- line counter
        BEGIN
            file_open(file_in, filename, read_mode);
            pixel_value <= (OTHERS => '0');
            WAIT UNTIL rising_edge(start);
            WHILE (NOT endfile(file_in)) LOOP
                readline(file_in, line_rd);
                read(line_rd, data_in);
                read_frame_array(i) <= std_logic_vector(to_unsigned(data_in, 8));
                pixel_value         <= std_logic_vector(to_unsigned(data_in, 8));
                i := i + 1;
            END LOOP;
            WAIT;
    dear schmalisch,
    actually the library did solve the compilation issue, but i do know getting some values in the following form instead of bits:
    uuuuuuuu
    uuuuuuuu
    uuuuuuuu
    at my simulation ? the matlab did show that the file contain character type , but you reading integer .. do you think that it is the reason??
    I see, you have to use the ieee.numeric_std.ALL instead of ieee.numeric_bit.ALL library.
    the error in this line command:
    Illegal type conversion from ieee.NUMERIC_BIT.UNSIGNED to ieee.std_logic_1164.STD_LOGIC_VECTOR (array element type difference).
    i have tried different library, but it still did not solve the issue ??
    thanks a lot for replying to my issue, but it does give me the following error for type of conversation
    What you see is the ASCII code of your text file.
    50 = 2
    49 = 1
    10 = line feed
    51 = 3
    48 = 0
    10 = line feed
    51 = 3
    try this code:
    LIBRARY ieee;
    USE ieee.std_logic_1164.ALL;
    USE ieee.std_logic_textio.ALL;
    USE ieee.numeric_std.ALL;
    USE std.textio.ALL;
    ENTITY feeder IS
        PORT (
            start       : IN  std_logic;
            pixel_value : OUT std_logic_vector(7 DOWNTO 0)
    END feeder;
    ARCHITECTURE Behavior OF feeder IS
        CONSTANT filename : string := "/afs/cad/u/s/m/smb34/vlsi2/frame1.txt";
        TYPE frame_array IS ARRAY (natural RANGE <>) OF std_logic_vector(7 DOWNTO 0);
        SIGNAL read_frame_array : frame_array(0 TO 25343);
    BEGIN
        read_file : PROCESS (start) IS
        BEGIN
            IF rising_edge(start) THEN
                    i := i + 1;
                END LOOP;
            END IF;
    END Behavior;
