Read flash attached to Max II in Parallel Flash Configuration on legacy system
Hi David,
Based on your description, I guess you want to read back the contents of the Micron Flash (28F128J3), right? From my point of view, this is quite difficult:
- The "Examine" function can be used to read back the MAX II internal program, that is, the contents of the MAX II cfm/ufm.
- The PFL IP itself does not have the ability to read back the contents of the flash; possibly the ASMI IP has this ability, but I’m not sure whether MAX II supports this IP.
- If it is purely about reading back the flash, the Micron manufacturer might be able to help you better. As far as I know, if you can connect to the flash pins, they can read back the contents of the flash using flash commands.
- However, even if you read back the image from the flash, it is, in my opinion, not feasible to reverse-engineer the .sof file from that image, so restoring the internal logic layout is not possible.
WZ
Thank you.
Mostly agree with your conclusions but not what you think I am attempting.
I don't care to reverse engineer the contents of the flash, I just want to be able to acquire them and place them on "blank" boards. I basically want to be able to take a working board and "clone" it to a blank board and have it behave exactly the same. To that end, I don't need to understand the flash contents, I just need to be able to duplicate them.
Had conversation with FAE and he gave me an idea that should work if I can extract / acquire a pin map between CPLD and flash chip.
- Save off current CPLD image (done)
- Write a new CPLD program from scratch that allows me to read and write flash through the JTAG terminal.
- Dump contents of flash to PC
- Dump flash contents to blank board using same program.
- Write back the original CPLD image from step 1 on both board.
That should work but I am currently stumped on a pin map. X-rayed the board but way to many layers and intersecting traces to get a pin map. In discussions with customer about cost / feasibility of pulling both CPLD and flash chips from a dead board and using a flying probe or manual labor to determine pin map.
Any thoughts or criticisms on this approach?
David
