10 years agoRead data from a SD card using an Altera Max II
Hi, I want to create a little board that has a Max II cpld and a Sd Card. The Max II version I´m using is Epm240t100c5n. I want to handle the Sd cart like a normal flash chip, so I need to pass so...
10 years agoMax II will handle the physical interface nicely - you'll be able to interface the SD card directly to I/O pins of the CPLD. However, the EPM240 isn't a particularly large part - it's internal resources are relatively limited. So, you'll be limited on how much functionality you can squeeze into it.
Based on what you describe, I suspect the EPM240 will have enough logic available for you to realise your goal. --- Quote Start --- Is there an easy way to implement this Sd interface? --- Quote End --- If you know what you're doing... I'm not sure how to answer that question without knowing how you intend to implement it. Can I assume you'll be writing some rtl? Cheers, Alex
