FvM
6 days agoHi,
PCIe reference clock is spread spectrum modulated on most system boards, this may cause locking issues. PCIe IP core PLL should have bandwidth settings that tolerate spread spectrum clocking, but system PLL probably has not. To check if the issue is related to spread spectrum clocking, you can disable it in BIOS setup.
Regards Frank
- SYiwe3 days ago
Hi Frank,
Thank you for your reply.
- How Can I confirm whether system PLL support spread spectrum modulated reference clock or not? I read PCIE IP and Native PHY user guide but no relative information found.
- Do you mean that I can try to disable PCIE card edge reference clock spread spectrum modulated function in BIOS when the main board linux system start up?
I will be appreciated if you can show me more suggestions, regards.
