miscellaneous-mice's avatar
miscellaneous-mice
11 days ago
Securing device: How to disable JTAG port?
Hello everyone, I am currently working on a design where we have strict security requirements. To prevent unauthorized readback, tampering, or reverse-engineering, our goal is to completely disable ...
  • FakhrulA_altera's avatar
    10 days ago
    For Cyclone V SoC, the JTAG pins are dedicated pins connected to the device’s TAP controller, so they cannot be reassigned as normal user I/O. This is why they are locked in Pin Planner and do not appear under Dual-Purpose Pins.
    For production security, the recommended method is to use the device’s Design Security features, in particular:
    • JTAG Secure Mode
    • encrypted configuration/programming
    If physical access also needs to be blocked, this should be done at board level, for example by removing or isolating the external JTAG connection.
    Please refer to Cyclone V Device Handbook Volume 1, Chapter 7: Configuration and Design Security, especially the sections on JTAG Secure Mode and Design Security Implementation Steps.
    Fakhrul
