Hi!
You are right I use the exact same board.
I used this GSRD from the rocketboards as a reference. But as I found out its u-boot doesn't enable FPGA-HPS bridges, so I have to build u-boot as described here https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderAgilex7 while using the same kernel and fsbl binary as in mentioned GSRD.
I have a custom module that holds asserted reset for couple of minutes so I have time to enable signaltap and observe its deasserting. But even without this module I see that after ninit_done is asserted i have RVALID high. I see this issue every time I boot the board.
Just want to check if you are also using the latest versions of the source code releases, U-boot = socfpga_v2023.10 etc..?
Okay, so using the GHRD from Rocketboards, the FPGA configuration is done right before "starting the kernel", including enabling the FPGA bridges:
Is it possible that you check again the signals behavior after booting to Linux as root in the signal tap? That would confirm that the bridge and FPGA enable and configured and the signal should behave as it should.
If you still see otherwise, let us know.
- Mikhail_a1 year ago
I use
U-Boot SPL 2023.07-rc6 (Nov 20 2023 - 08:40:20 +0000) - got from GSRD
andU-Boot 2023.10-31805-g69d5338be0-dirty - built by myself according to rocketboards guide
and boot log looks like this:
CPU: Intel FPGA SoCFPGA Platform (ARMv8 64bit Cortex-A53)
Model: SoCFPGA Agilex SoCDK
DRAM: 2 GiB
Core: 28 devices, 23 uclasses, devicetree: separate
WDT: Started watchdog@ffd00200 with servicing every 1000ms (10s timeout)
MMC: dwmmc0@ff808000: 0
Loading Environment from FAT... OK
In: serial0@ffc02000
Out: serial0@ffc02000
Err: serial0@ffc02000
Net: eth0: ethernet@ff800000
Hit any key to stop autoboot: 0
10739712 bytes read in 499 ms (20.5 MiB/s)
FPGA not ready. Bridge reset aborted!
...........FPGA reconfiguration OK!
38816256 bytes read in 1817 ms (20.4 MiB/s)
32237 bytes read in 5 ms (6.1 MiB/s)
RSU: Firmware or flash content not supporting RSU
## Flattened Device Tree blob at 08000000
Booting using the fdt blob at 0x8000000
Working FDT set to 8000000
Loading Device Tree to 000000007eafb000, end 000000007eb05dec ... OK
Working FDT set to 7eafb000Starting kernel ...
Deasserting all peripheral resets
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
