mfbm
1 month agoThank you for the answer.
But I still don't understand the benefit of using 1,8V LVCMOS if, according to the datasheet, the maximum Altera is guaranteeing is 200 MHz for both standards: "I/Os using general-purpose I/O standards such as 3.3-, 3.0-, 2.5-, 1.8-, or 1.5-LVTTL/LVCMOS are capable of a typical 200 MHz interfacing frequency with a 10 pF load." Maybe 1,8V standard would support higher frequencies but if this is still not guaranteed by the manufacturer, the limit is still 200 MHz.
Mabel
AdzimZM_Altera
1 month agoHi Mabel,
Let's use 200MHz as the limit since it has been mentioned in datasheet.
I think if using higher frequency, there might be some difficulty to meet timing.
Adzim
