Farabi
1 year agoHello,
Basically, yes, you can use the same .sof file and convert to AS or PS programming files.
regards,
Farabi
Steve-Mowbray-ENL
1 year agoHi Farabi
Quick update with some results for posterity:
- JIC files always same size regardless of generated from active or passive serial SOF files...
- passive serial RBF files generated from active serial SOF files are approximately twice as big as passive serial RBF files generated directly by Quartus -- not sure why this would be but means is more attractive to make the default build passive serial
- I have programmed a platform with a JIC converted from passive serial SOF and it has programmed and runs correctly with MSEL pins set to active serial configuration mode...
Steve
