JayHarikumaran
4 years agoMAX 10 JAM player programming failure
I had raised this issue before. The question was unfortunately closed off without a solution.
https://community.intel.com/t5/Programmable-Devices/JAM-Player-exit-code-10-Device-Programmi...
JayHarikumaran
4 years agoHi dabo,
Thanks a lot for the suggestions.
I created a jam file with Program/Configure or Verify checkboxes unchecked with and without the real-time ISP enabled.
I also used the quartus_jbcc.exe to generate the jbc file.
We call the jbi_execute twice. Once with action "PROGRAM" and secondly with "VERIFY". Ill check how to enable the optional procedure.
As for the results, it is unfortunately still the same. When I disable ISP, I see that the generated filesizes are higher but I get the exit_code 10 "exit_string = "Device programming failure";
If I enable ISP, the device is erased but not programmed.
Jay
