Hi Serge,
Thanks for the update. Could you try below:
- Return all switches to Default Settings. Include: SW2[1:3] = OFF/OFF/OFF (JTAG mode), SW5.1 = OFF (on‑board Download Cable), SW5.2 = OFF (FPGA in chain), SW5.3 = ON (MAX 10 JTAG enabled). If your board uses SW8 instead of SW5, use the equivalent entries in the same table. Refer: Default Settings tables.
- Check the D6 Power Good LED. Blue ON means all rails are good. If OFF, address power first. Refer: LEDs table.
- In BTS, open Power Monitor GUI and capture the rail status screenshot. Refer: “Monitor On‑board Power through Power Monitor GUI.”
- In Quartus Programmer, run JTAG Chain Debugger and share the integrity report if auto‑detect still fails. Intel help recommends this when the chain cannot be scanned.
- Perform Board Restore through Quartus Prime Programmer, then power cycle and retry JTAG. Refer: “Perform Board Restore through Quartus Prime Programmer.”
You may refer to this user guide for the above steps: Agilex™ 7 FPGA I-Series Development Kit User Guide
If the chain is still broken with the FPGA in the path after the above, it suggests a board‑side JTAG issue, it can indicate a board integrity problem once power and connections are confirmed. We can proceed with RMA.
Please also share clear photos or a list of the current SW1–SW6/SW8 positions.
Fakhrul
Hello Fakhul,
So,
About (1) : I have set all the switches as asked, please see the picture attached.
About (2) : Unfortunately The LED D6 is Off.
About (3) : See the picture attached, I cannot communicate with the board, So I cannot get any voltage value.
About (4) : Please see the attached picture.
About (5): I had to use the J10 instead of J8 to be able to reconfigure the MAX10, otherwise I cannot get the JTAG chain and so I cannot configure the MAX10. I power cycle and the JTAG is still the same...
Thank you for your help.
Serge
