Re: Inquiry Regarding Cyclone V IBIS Model Definitions and Updates
thanks for correction. Now I get your point.
lvcmos_xxx_d2xx Ibis I/V curves don't look like 2 mA current strength, according to datasheet specification (0.2 V max. voltage drop at nominal current) it rather looks like 8 mA. Unfortunately I have no Cyclone V board at hand and can't check if lvcmos_d2 I/O standard is setting current strength that high or if it's only an IBIS file error.
I can tell that e.g. Cyclone 10LP has consistent current strength settings and IBIS files.
In contrast, the relation of Cyclone V lvcmos30 and lvttl30 I/V curves looks consistent. See below a visualization.
Best regards
Frank
- RyusukeYOKOYA1 year ago
Hi Frank,
Thank you very much for taking the time to review the details and for providing additional insights.
I also find it difficult to determine whether this behavior is part of the intended specification or simply an error in the IBIS file. Given the ambiguity, I would appreciate it if an Intel employee could help clarify this point.
Thanks again for your support.
Ryusuke YOKOYA- FvM1 year ago
I got hold of an old Cyclone V based PCA and was able to measure drive strength of lvcmos 3.3V output. I found that is nearer to lvttl_d4 than lvttl_d16, in other words, just what we would expect for lvcmos_d2. Suggests that lvcmos_d2 spec in Cyclone V IBIS file is wrong and doesn't represent actual device behaviour.
Frank
