Hello FvM,
Thanks for your response. Yes I did try to follow the steps mentioned in the user guide and the switch configuration mentioned there.
There are couple of updates and questions from my end.
1) There was an option to add flash manually in the programmer, by clicking on the cpld (5M2210Z). I was able to add the CFI flash and it is showing up in the tool. image below. Is this also a correct way to add the flash?
2) Let's say I would like to go with pof option using the above step, will it still be fine? If yes, then which mode should I use to generate the pof?. where should I find that information?
3) Once I generate the pof with correct mode and configuration, should I program the CFI flash and then also the pag_0 and option_bits as shown below?
thanks for your time.
