Adams_Hu
1 year agoFlash Loader IP missing on Cyclone IV GX?
Hola Generating a JIC with EPCGX30CF32 to program a serial flash by Convert Programming files. However Quartus shows no Flash Loader IP after first device programmed. Could you upload a proper fla...
Adams_Hu
1 year agoHi Fakhrul
It is still a problem to download JIC via default Flash Loader IP.
BXia
1 year agoYou can refer to the advice in this post: https://community.intel.com/t5/Programmable-Devices/Flash-Loader-IP-not-loaded-on-device-1/m-p/1447330?profile.language=zh-CN
- FvM1 year ago
@BXia.pof is no option for a serial flash without dedicated AS programming connection.
I also don't think that the linked previous thread helps here. As far as I undertstand error "Flash Loader IP not loaded" indicates that the expected virtual JTAG node ID isn't actually present in the loaded configuration or can't be identified due to JTAG issues. The linked thread shows that a too high JTAG frequency in case of programmable speed can be a reason.- Adams_Hu1 year ago
Hi Frank
Few questions
- If USB-Blaster II freuqncy is too high, why 1st SOF can be loaded into Cyclone IV GX FPGA?
- I ever set USB-Blaster II frequency down to 6MHz but it shows the same fails. If the JTAG frequency is an issue, how low frequency is suitable for test?
- FvM1 year ago
SFL IP is involving virtual JTAG logic, can have different frequency limit than loading .sof.
But problems below 12 MHz are hardly expectable.
