HI,
So your intention is to use SDI IP and not HDMI IP ?
Sorry but I am not familiar with SDI IP implementation, hence can't give you further advise.
But from the look of this issue, likely this is limitation of NativePHY IP itself where the XCVR_CONFIG_GROUP command can only works with same logical channel as I explained to you earlier.
I am not aware of any workaround.
- so you must either use same logical channel to fit into same physical channel pair
- or totally split Tx and Rx channel into different physical channel then there is no need to merge them anymore
dlim
