Hi HAlex,
Based on current information, it is difficult for us to provide justification ie. this issue is due to jic file or not. However, may I know what is the version you're using now?
Are you performing any encryption in your programming?
There are a few KDBs may be related to your issue; some are not but it is worth the check it out:
Error (209014): CONF_DONE pin failed to go high in device 1
Error (209014): CONF_DONE pin failed to go high in device 1.
Error (209014): CONF_DONE failed to go high in device <number>
Fakhrul
Hello
I am using Quartus Prime Version 21.1.0 Build 821 10/21/2021 SJ Standard Edition.
I don't have an encryption.
Tried to burn also with latest Quartus standalone programmer only with different verified jic and sof (only for FPGA download) files but without success.
Is it possible that FPGA is damaged (as sof file not working)? Or it still can be related to possible corrupted contents of flash that somehow overcomes even FPGA only sof file download attempts?
Thank you.
Alex
