AdzimZM_Altera
6 hours agoHi Steve9 ,
"Can Altera explain why they recommend pullup which seems to be opposite of what memory vendor specifies?"
The power need to apply to reset_n pin at power-up sequence as mention in datasheet.
"why the eval board implementation for this signal termination does not match the EMIF user guide figure 143 recommendation?"
There are multiple termination scheme that has been used to terminate the clk signal. You can also terminate the signal to VDD. Also can terminate to both VDD and GND.
I think the board designer should identify which termination scheme that suitable for their board.
Adzim
